[Risolto] Program crashes during slicing
Fitz
 Fitz
(@fitz)
Every time I try to slice a model after setting up an stl for the Mini the program crashes. No error codes or notices. What's wrong?
Postato : 06/01/2020 8:24 pm
Area51
(@area51)
Utenti
RE: Program crashes during slicing
Do the model have any errors and if so, did you repair them before slicing.
Errors to PrusaSlicer can be reported as issues here on GitHub: https://github.com/prusa3d/PrusaSlicer/issues
Postato : 06/01/2020 11:33 pm
Fitz
 Fitz
(@fitz)
Everything looks ok before slicing.
Postato : 07/01/2020 2:27 pm
Area51
(@area51)
Utenti
Is it the specific model or all STL models?
Which version of PrusaSlicer (PS) is it, OS?
Have you tried to reinstall the program (reset setup)?
Postato : 07/01/2020 4:08 pm
Fitz
 Fitz
(@fitz)
@area51
All .stl files.
2.1.1 win64.
Have tried reinstall.
Postato : 07/01/2020 10:00 pm
Area51
(@area51)
Utenti
Is it only when slicing to the Mini or also when slicing to other models?
You could try the latest 2.2.0 Alpha version - It is fairly stable and I use it over 2.1.1 now.
Postato : 08/01/2020 1:12 pm
Fitz
 Fitz
(@fitz)
@area51
Using 2.2.0 I get message "unable to enumerate device". Whats up?
Questo post è stato modificato 6 years fa da Fitz
Postato : 13/01/2020 2:53 pm
Area51
(@area51)
Utenti
An error like "unable to enumerate device" could point to an USB device or Graphic card. I would guess that it could be an USB as the new Alpha release tries to locate USB devices (memory sticks) when exporting the generated G-code.
That is properly not helpful - I would report it as an issue on GitHub and hope the Prusa developers have an answer.
PrusaSlicer GitHub issues: https://github.com/prusa3d/PrusaSlicer/issues
Postato : 13/01/2020 11:31 pm
