print fan is not spinning error
Michal Bartak
(@michal-bartak)
Recently I encountered this error "print fan is not spinning" error twice. It caused immediate print interruption.
The error is displayed on the control panel. The Print Fan did not spin indeed. Attempts, with use of a finger, to make it work give no results.
But turning the printer off and on again, makes the fan spin again.
On the Internet, I found suggestions to disable fan check.
Is it a known issue? Does that mean that the fan deserves replacing? Or it's software problem?
Edit: I disabled Fan control and started the next print. After some while I found that the Print Fan is not spinning. In the control panel, in tuning section I found it's turned off.
Opublikowany : 14/12/2024 6:26 pm
jsw
 jsw
(@jsw)
RE: print fan is not spinning error
I do not have the Mini, but my MK3 has been running fine with the fan check disabled for maybe three years or so.  I just got tired of the (false) alarms/aborts that some glitch is causing.
Opublikowany : 14/12/2024 6:54 pm
_KaszpiR_
(@_kaszpir_)
I had that fan issues with a Fiberology filament, the fix is to increase minimum fan speed in filament profile, see https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/hotend-fan-not-spinning-check-it-for-possible-debris-then-inspect-the-wiring-error/#post-726328
Opublikowany : 15/12/2024 9:15 am
Michal Bartak
(@michal-bartak)
Thanks.
That reminds me, that those fan errors appeared after I changed filament to PM FRJet (Before, I was printing using Prusament only).
But I use the official PM FRJet filament profile delivered by Prusa. Indeed, it has a fan speed range of 5-15%, while Prusament PETG profile has 30-50%.
This post was modified 1 year temu by Michal Bartak
Opublikowany : 15/12/2024 10:42 am
_KaszpiR_
(@_kaszpir_)
Some profiles lag behind the firmware versions, which started to require certain minimum values, such as fan speed.
IL check on GitHub because this starts to be an issue because some presets are just old.
Opublikowany : 15/12/2024 6:27 pm
_KaszpiR_
(@_kaszpir_)
reported to https://github.com/prusa3d/PrusaSlicer-settings/issues/282
Opublikowany : 15/12/2024 9:30 pm
