Periodically inconsistent extrusion / Cyclic under extrusion
FARO
 FARO
(@faro)
Miembro
Hi Community,I have a very persistent problem with Inconsistent Extrusion.The error is most likely related to the amount of filament extruded and the extruder rotation, not to time, temperature control or X/Y movement.
The extrusion errors always occur after a certain amount of filament has been extruded and are independent of the print speed.
  • The error occurs at regular intervals.
  • The interval is constant.
  • The interval remains the same even when the print speed is changed.
I think is very likely that there is a mechanical or feed-related periodic error, however I checked the extruder (driver gear and driven gear) multiple times and cleaned it although it looked totally fine.
I can't imagen that the hotend, PTFE, temperature, slicer, etc. produce precisely periodic errors, so I would rule these out as sources of the error.
987uzdefry Additional Info:
  • Printer: Prusa Mini+ (tried with and without case)
  • Filament: Polyterra PLA (Polymaker) and PETG Polymaker
  • Nozzle: Tried both the original 0.4 and the E3D V6 Plated Copper 0.6 mm (problem occures with both nozzles)
  • Bed Temperature PLA: 60 Celcius
  • Prusa Slicer
  • Print Speed: tried 15, 30 and 45 mm/s (First Layer Speed because it's only a single layer print)
  • Retraction settings: (Prusa PLA standard)
    • Length: 2.5 mm
    • Speed: 70 mm/s
I tried a lot of different Slicer settings, but they had little to no effect, so I decided to continue the rest of the testing with the standard prusa slicer "0.20 mm STRUCTUAL" settings with the 0.4 Nozzle
I already tried a lot of different things:
  • Bondtech gear cleaned → minimal contamination
  • Idler screw adjusted
  • Z-axis lead screw cleaned and lubricated → no improvement
  • Drive gear visually inspected → appears to be in good condition
  • PTFE insert in the hotend inspected → looks good
  • No filament buildup in the hotend
  • Cold pull performed multiple times → no improvement
  • Tested multiple filament spools
  • Tested different print parameters
  • Changed extrusion multiplier → no improvement
  • Reduced print speed → no change
  • Increased temperature → errors become a little less severe, but remain present
Really hope you can help💫
Let me know if I should provide any additional info.
Respondido : 20/03/2026 5:26 pm
