Perimeter vs infill
atomleef
(@atomleef)
Perimeter vs infill
I am trying to print a door opener hook for anti covid19 usage, for strongest print i should to add more perimeter or infill? What different between add more perimeter or infill?
thank you
Veröffentlicht : 12/01/2021 4:08 am
Area51
(@area51)
Mitglied
RE: Perimeter vs infill
In my experience adding more perimeter will make the part stronger - infill above 25-30% will not significantly add to strength.
It is like with tubes, stronger constructions is often made up of tubes instead of solid rods - that gives the highest strength for a given weight.
Veröffentlicht : 12/01/2021 4:20 am
atomleef
(@atomleef)
thank you 🙂
Veröffentlicht : 12/01/2021 5:00 am
P.Stock
(@p-stock)
@atomleef
Keep in mind to add same amount of TOP and BOTTOM layers e.g. 5 bottoms + 5 top layers and 5 perimeters to get the same strength through the whole object.
Veröffentlicht : 12/01/2021 8:57 am
atomleef
(@atomleef)
@p-stock
that very nice tip thank you
Veröffentlicht : 12/01/2021 9:02 am
