my mini isn't printing on same location as prusaslicer is showing
phidippus_fan
(@phidippus_fan)
hi.
printer pics: https://photos.app.goo.gl/NxCtvJaL25fhvSpn7
thanks.
Veröffentlicht : 04/07/2021 11:05 pm
RE: my mini isn't printing on same location as prusaslicer is showing
Are you sure?  Is the steel sheet on straight..?
Veröffentlicht : 05/07/2021 12:11 am
phidippus_fan
(@phidippus_fan)
i guess so?
Veröffentlicht : 05/07/2021 12:12 am
Loewekordel
(@loewekordel)
Discussion already in the following forum entry:
https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/heatbed-not-centered/#post-503305
Veröffentlicht : 19/09/2021 2:42 pm
MysDawg
(@mysdawg)
Slicer
Have you selected the correct printer in the slicer?
If you are printing from a file that someone made is the g-code set for your printer?
Veröffentlicht : 19/09/2021 4:20 pm
phidippus_fan
(@phidippus_fan)
hhhhh
yes. correct printer selected in prusaslicer
i never use others gcode
Veröffentlicht : 19/09/2021 4:26 pm
Area51
(@area51)
Mitglied
Check end stops for X and Y axis
The Mini is resetting the axis by running the X and Y motors until they hit the end stop (end of axe). If there is something obstructing this movement and makes an early stop, the zero point of X and/or Y axis will be wrong for the print.
Please check if X and Y axis can move freely to the end stops.
I have had failed prints because the build plate hit something I had standing behind the printer and calibrated the end of Y axis wrong.
Veröffentlicht : 20/09/2021 12:08 am
Loewekordel
(@loewekordel)
Slicer / end stops ok
I also only use self-sliced gcode.
X and Y axis work properly.
Veröffentlicht : 02/10/2021 8:33 am
