my mini isn't printing on same location as prusaslicer is showing
hi.
printer pics: https://photos.app.goo.gl/NxCtvJaL25fhvSpn7
thanks.
RE: my mini isn't printing on same location as prusaslicer is showing
Are you sure? Is the steel sheet on straight..?
i guess so?
Discussion already in the following forum entry:
Slicer
Have you selected the correct printer in the slicer?
If you are printing from a file that someone made is the g-code set for your printer?
hhhhh
yes. correct printer selected in prusaslicer
i never use others gcode
Check end stops for X and Y axis
The Mini is resetting the axis by running the X and Y motors until they hit the end stop (end of axe). If there is something obstructing this movement and makes an early stop, the zero point of X and/or Y axis will be wrong for the print.
Please check if X and Y axis can move freely to the end stops.
I have had failed prints because the build plate hit something I had standing behind the printer and calibrated the end of Y axis wrong.
Slicer / end stops ok
I also only use self-sliced gcode.
X and Y axis work properly.
