Idler Tension
Swishtail
(@swishtail)
Idler Tension
Peeking through my PFTE tube, I see little teeth marks in my filament as it heads from the extruder to the hot end.  Is this normal?  Is my idler tension perhaps a bit too tight?  I desperately want to avoid clogging the machine, as the last time I did, I essentially replaced the entire hot end trying to get it clear, clean, and running again.
Napsal : 29/10/2020 7:09 pm
RE: Idler Tension
Tooth marks are why the drive gears have teeth.  Normal. If the filament is flattening, then that's probably too much.
Napsal : 29/10/2020 7:18 pm
Swishtail
(@swishtail)
RE: Idler Tension
@tim-m30
Thank you.  Yes, I’m seeing teeth marks rather than the deep gouges I saw before when I had a major clog.
Napsal : 30/10/2020 12:51 am
1 lidem se líbí
herbert
(@herbert)
RE: Idler Tension
This is how someone from Prusa Support showed me how to setup the idler tension
https://imgur.com/kSLQHEt
Special care should only be taken if using flex materials, because they are softer otherwise his advice was
Generally speaking - more tension should be better than less tension. Although, less tension is needed for example for the flexible filament 🙂
Napsal : 30/10/2020 10:45 am
2 lidem se líbí
toz
 toz
(@toz)
RE: Idler Tension
@herbert
video would be of great help in the instruction for the mini, or not?
helped me a lot to clearify how this setting should be
Napsal : 31/10/2020 3:59 pm
herbert
(@herbert)
RE: Idler Tension
The prusa-support-engineer knows about how helpful this video was for me and tries to get this into the official documentation 😉
Napsal : 02/11/2020 10:42 am
