Help identifying problem with a print
MAX1
 MAX1
(@max1)
Can you look at a print I am making on a prusa using overture petg. It seems to make an imprint or go bad only in the top right hand corner.
this is consistent on multiple prints in the same spot.
what is the cause of this?
I changed the z layer to make it closer and it seems to still have this problem in the corner.
This topic was modified před 4 years 2 times by MAX1
Napsal : 15/03/2022 12:44 am
ezeackermann
(@ezeackermann)
RE: Help identifying problem with a print
Hi Max,
If instead of printing the piece in the center of the bed, you print it on one edge, does it do the same for you?
Verify that the printing base is clean, especially in textured sheets, the same grease from the fingers makes the material not stick.
Try cleaning the bed, isopropyl alcohol (IPA). In some cases, they recommend cleaning the sheet with warm water and detergent with a non-scratch sponge.
Napsal : 15/03/2022 2:34 am
There may be an oil spot on the print sheet causing poor adhesion just in that position.  Try cleaning it.
Napsal : 15/03/2022 1:46 pm
And clean it with hot water and additive free dish washing soap, not just IPA.
Napsal : 15/03/2022 2:42 pm
MAX1
 MAX1
(@max1)
Thank you for the suggestions.
I spread the print across the plate. I also cleaned the plate and flipped it. If you study the photo below, you can see the bottom right print is perfect. Top left is perfect. Other prints on the plate all have some defects. Is there a reason why some areas have less problems than others?
hotend loose?
filament feeder?
something else?
or is this normal behavior?
attached
Napsal : 15/03/2022 3:51 pm
Files > Save Project as
Napsal : 15/03/2022 9:03 pm
