Firmware already available?
Nikolai
(@nikolai)
Hi guys,
Have you found the firmware source already? I was looking on github but couldn't find it so far. Would be great if someone could provide a link.
Thanks!
Best Answer by Nikolai:
Here we go. Source code is available on github now: https://github.com/prusa3d/Prusa-Firmware-Buddy
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 16/12/2019 9:39 pm
Clemens M.
(@clemens-m)
RE: Firmware already available?
What's wrong with firmware 4.0.0 directly from the homepage?
https://www.prusa3d.com/drivers/
Best regards,
Clemens Mödlin
Opublikowany : 17/12/2019 6:57 am
Nikolai
(@nikolai)
@clemens-m
I see only binary there.
Often linked posts:
Real Multi Material
Opublikowany : 17/12/2019 7:02 am
Clemens M.
(@clemens-m)
That is the download you can make there for the Mini:
Best regards,
Clemens Mödlin
Attachment removed
Opublikowany : 17/12/2019 7:14 am
Nikolai
(@nikolai)
@clemens-m
Thanks for providing the binary. I'm still looking for the source code. Do I miss something?
Often linked posts:
Real Multi Material
Opublikowany : 17/12/2019 7:17 am
Olef
 Olef
(@olef)
No source has yet been published as far as I can find. It will appear on Github I imagine when released https://github.com/prusa3d
Opublikowany : 17/12/2019 9:13 am
Nikolai
(@nikolai)
Often linked posts:
Real Multi Material
Opublikowany : 20/12/2019 11:15 pm
Mike
 Mike
(@mike-38)
Is firmware flashed the same way as the MK3s - ie, using PrusaSlicer?
Opublikowany : 21/12/2019 2:03 am
Area51
(@area51)
Just copy it to the USB stick and insert into Mini.
Opublikowany : 21/12/2019 2:07 am
Nikolai
(@nikolai)
But only official signed firmware can be flashed right now or you have to remove the appendix. (Which will void the warranty)
Often linked posts:
Real Multi Material
Opublikowany : 21/12/2019 2:33 am
Area51
(@area51)
I understand that PR wants to protect against bad firmware on the net, but it also stops us more experienced users to experiment and tweak the firmware to remove bugs and test changes before reporting them to PR.
As the Mini is a new printer model (with unknown issues), I would hate to loose the warranty, just to play around with the firmware to make it better...
Opublikowany : 21/12/2019 5:23 am
