Faulty extruder thermistor ?
Texy
 Texy
(@texy)
I am getting less than favourable prints and the occasional sound of 'popping' when printing. I believe the extruder thermistor is reading lower than the actual temperature, resulting in higher print temperatures. I am getting 'gaps' and 'blobs' as well as more than expected stringing :
As an experiment, I lowered the extruder temp to 205, down from 215 and got a better print :
Anyone else had a problem with the extruder thermistor on their Mini ?
Texy
Opublikowany : 21/04/2020 8:58 am
Texy
 Texy
(@texy)
RE: Faulty extruder thermistor ?
Incidentally the same reel of PLA is now printing fine on my MK3 at 215'c.
Texy
Opublikowany : 21/04/2020 8:59 am
Posted by: @texy
Texy
I would measure the thermistor once. It should have a resistance of approx. 100kohms.
Opublikowany : 21/04/2020 10:04 am
Texy
 Texy
(@texy)
Posted by: @karl-herbert
Posted by: @texy
Texy
Good plan, thank you. I measured it today after removing the connector from the Buddy board and at 16'c it is measuring 136K. I have a spare thermistor for my mk3 and it measures 131K - do you think this is enough difference ?
Texy
Opublikowany : 22/04/2020 7:09 am
@texy
Here a thermistortable (NTC 100k):
https://www.makeralot.com/download/Reprap-Hotend-Thermistor-NTC-3950-100K.pdf
Thermistor resistance should be about 100k at 25degree C. (about 150k at 16degree C.). The deviation from 131k should be about 3 degrees. I think the temperature will not change drastically with the new thermistor, but you can temporarily connect it for testing. The temperatures are theoretical values anyway, so it is best to test them on each filament and adjust them if necessary. The same for the heating bed.
Opublikowany : 22/04/2020 12:11 pm
Texy
 Texy
(@texy)
I contacted prusa online chat and they had me measure the hotend ptfe tube length - it was short at 42mm. I measured the spare one which was the correct length and fitted that. No improvement with the print quality, but further investigation shows that it is that particular reel of white PLA causing the issue. My MK3 seems to handle this reel much better (although not perfectly), so maybe the Mini is not so tolerant of poort filament?
Texy
Opublikowany : 23/04/2020 6:53 am
