Extruder Tension Adjustment
sberesfo
(@sberesfo)
Hello,
I am curious if there is a way to adjust the extruder tension against the filament on the Mini+.
Thank you,
Scott
Napsal : 29/12/2024 2:17 am
_KaszpiR_
(@_kaszpir_)
RE: Extruder Tension Adjustment
Do you mean idler screw on the side of the PTFE tube that goes into the extruder? https://help.prusa3d.com/article/idler-screw-tension_177367
Napsal : 29/12/2024 7:03 am
sberesfo
(@sberesfo)
Hi, The link you provided does not address the mini+. We want to reduce the pressure the extruder gear is squeezing the filament. This is very easy to do on the MK3S and we are curious if there is a similar adjustment on the mini+.
Napsal : 29/12/2024 7:23 pm
The link does address the Mini and Mini +.  It contains adjusting for a wide range of prusa printers as well as the MMU.  Please look again.
If you want to get more specific https://help.prusa3d.com/article/idler-screw-tension_177367#mini-mini
Napsal : 29/12/2024 9:34 pm
sberesfo
(@sberesfo)
Thank you! Yes, I did make a mistake. That link was exactly what I needed. Thank you again.
Napsal : 29/12/2024 10:25 pm
