Bad PETG prints after software upgrade
Andrew Meler
(@andrew-meler)
Utenti
I recently upgraded from an early software version to the latest available.  PETG prints now have missing chunks at the top edge.  Is there a way to avoid what's in the picture
Postato : 30/12/2024 8:58 pm
_KaszpiR_
(@_kaszpir_)
RE: Bad PETG prints after software upgrade
Is this with the same gcode as before?
Postato : 31/12/2024 7:54 am
Andrew Meler
(@andrew-meler)
Utenti
Yes, the same GCode was used initially, but then I re-sliced thinking it would fix the issue (it didn't).
This is odd, as it only happens in the top layer on this specific print. I have been playing with temperature and flow rate, but nothing seems to work.
PLA prints look fine.  PETG is not (I have 2 spools of PETG) .  I dried the filament, but it didn't help.
Postato : 31/12/2024 3:40 pm
carlmmii
(@carlmmii)
What nozzle size and temperature are you printing at? The image of the side wall looks like you're underextruding based on the uneven ripple patterning.
Postato : 02/01/2025 5:08 am
_KaszpiR_
(@_kaszpir_)
One more thing, if you upgrade firmware then remember to upgrade also PrusaSlicer and check for the profile upgrades and redo your custom profiles.
I remember I had issue with few profiles in PrusaSlicer so I recreated them from scratch.
This was especially visible when bumping to firmware 6.x.x and PrusaSlicer 2.8.x
Postato : 02/01/2025 7:58 am
