Help Calibrating Prusa Core One for PEBA 85A
John Mills
(@john-mills)
Mitglied
Hi all!
I'm looking for some help/advice on calibrating my printer/profile for Siraya Tech's Rebound PEBA 85A ( https://siraya.tech/pages/siraya-tech-rebound-peba-85a-user-guide).   This is my first time trying to print flexible filament, so I started by following the OrcaSlicer calibration guide ( https://www.orcaslicer.com/wiki/calibration/calibration_guide.html).
I started with the temperature tower and at first selected 255C; this print had issues with the top layer of each section (see photos in links below).
Next I did the max volumetric speed test, which had no notable issues; I selected 3 mm^3/s (sorry, no pictures of this print).
Here's where it got complicated.  Next was the pressure advance test where I struggled to find a good value.  I searched for advice on this test for flexible filaments, but struggled to find anything helpful/applicable.  I tried the "line pattern" and the "chevron pattern" and both either gave inconclusive results, or too poor quality to make a good judgement.
Basically at this point I decided to just go for the part I wanted to print to see how bad it turns out.  It actually wasn't terrible, but as you can see from the photos, far from ideal.
So, I'm hoping to get some advice for how to proceed with tuning my filament profile and/or modifying my print settings or model. Thanks!
Here's additional details to help:
PEBA in dry box, direct feed to extruder:
Veröffentlicht : 24/05/2026 5:09 am
