Raspberry Pi Zero W 2 on MK4/S
Jesse
(@jesse-7)
I added a Pi Zero 2 W to my i3 MK3S+ to run PrusaLink.  The transfer upload rate is about 50 mb/s.  In comparison, the MK4S is only about 2 mb/s on ESP.
Is it possible to put a Pi Zero into the MK4/S?  Can the Pi can do everything the ESP does?  The Pi costs $10 at Microcenter.  I see that a physical adapter might be needed to match up the pins.
Postato : 12/03/2025 12:05 am
Walter Layher
(@walter-layher)
RE: Raspberry Pi Zero W 2 on MK4/S
The xBuddy board of the MK4 series does not have the pins that were present on the Rambo board of the MK3 series. But this was just a serial connection. You should be able to replicate this with an adapter cable micro-USB to USB-C and then set up a serial connection/port in the config of the Pi Zero.
I have no experience with PrusaLink, I use OctoPrint and there you also use a serial-over-USB connection to connect to the printer. On MK3 series printers you could also use the same onboard pin connection with OctoPrint and a Pi Zero.
Postato : 12/03/2025 12:28 am
Jesse
(@jesse-7)
The MK4/S electronics are slower to save files and Wi-Fi is not the bottleneck.  The Ethernet port is equal in speed to Wi-Fi.
Postato : 12/03/2025 4:47 pm
