Vase is filled in - award wining file from Printables
Debbie Shaver
(@debbie-shaver)
Utenti
I am a newbie and have successfully printed 4 different files so far.  I downloaded an award winning spiral cup from Printables and the cup is filled in with support brackets (kind of like latice work).  I have researched on this forum and verified my slicing mode is set to regular.  I don't understand enough about SketchUp or Fusion to figure out if there is something that needs to be fixed with this file.  I've attached the g-code.  If someone can help me figure out...do I have an incorrect setting in trying to slice this?  Is the .stl file from Printables a bad file?  Any help is greatly appreciated!!pen_cup_d8h9_0.4n_0.2mm_PLA_MK4S_8h6m
Best Answer by Walter Layher:
Put a checkmark next to "Spiral vase" and everything will be fine. 🙂
Postato : 31/08/2025 4:49 am
Debbie Shaver
(@debbie-shaver)
Utenti
RE: Vase is filled in - award wining file from Printables
pen_cup_d8h9
Oops - just realized the file needed is the 3mf file.  See above
Postato : 31/08/2025 5:20 am
Walter Layher
(@walter-layher)
Postato : 31/08/2025 8:57 am
Debbie Shaver
(@debbie-shaver)
Utenti
I have so much to learn!  Thank you!
Postato : 31/08/2025 3:45 pm
