Vase is filled in - award wining file from Printables
I am a newbie and have successfully printed 4 different files so far. I downloaded an award winning spiral cup from Printables and the cup is filled in with support brackets (kind of like latice work). I have researched on this forum and verified my slicing mode is set to regular. I don't understand enough about SketchUp or Fusion to figure out if there is something that needs to be fixed with this file. I've attached the g-code. If someone can help me figure out...do I have an incorrect setting in trying to slice this? Is the .stl file from Printables a bad file? Any help is greatly appreciated!!pen_cup_d8h9_0.4n_0.2mm_PLA_MK4S_8h6m
Veröffentlicht : 31/08/2025 4:49 am
RE: Vase is filled in - award wining file from Printables
Oops - just realized the file needed is the 3mf file. See above
Veröffentlicht : 31/08/2025 5:20 am
I have so much to learn! Thank you!
Veröffentlicht : 31/08/2025 3:45 pm
