Top Layer
Grandpa Joe
(@grandpa-joe)
Top Layer
I would like a smoother top layer.
Is one of the preset Print settings better to use?
Opublikowany : 20/01/2026 9:58 pm
The ironing function is intended to smooth top layers - but for your print I would just flip it over and print face down - then your choice of build plate dictates the surface finish.
Opublikowany : 20/01/2026 11:17 pm
1 ludzie polubili
Grandpa Joe
(@grandpa-joe)
RE: Top Layer
Im also not getting a great first layer.  This is Hatchbox, which I usually have good results with.
Opublikowany : 20/01/2026 11:27 pm
Grandpa Joe
(@grandpa-joe)
RE: Top Layer
I looked again, I thought this was Hatchbox, but no -  it;s Jessie premium PLA from  PrintedSolid.com
Im going to go back to my Hatchbox filament.
Opublikowany : 20/01/2026 11:39 pm
That's slightly odd - try turning the build sheet over, does the same effect appear on both sides?
Opublikowany : 21/01/2026 4:56 am
Grandpa Joe
(@grandpa-joe)
RE: Top Layer
no, the bottom is pretty smooth most of the time.   Sometimes both bottom and top are bad.  Just not consistent.
Opublikowany : 01/02/2026 2:07 am
Grandpa Joe
(@grandpa-joe)
RE: Top Layer
I have tried Hatchbox and i am still getting random streaks.
Opublikowany : 01/02/2026 2:11 am
Grandpa Joe
(@grandpa-joe)
RE: Top Layer
yes
Opublikowany : 04/02/2026 3:37 pm
Grandpa Joe
(@grandpa-joe)
RE: Top Layer
The side of the build plate used does not matter.
Opublikowany : 04/02/2026 3:39 pm
