Problem with elastic filaments
amir faqihi
(@amir-faqihi)
Mitglied
Hi, i want to print some models with TPU filaments (elastic ones), but the thing
Is that right around the feeding gears the filamets jams and gets tangled, what do you suggest?
Veröffentlicht : 23/07/2025 6:57 pm
Zwirbel
(@zwirbel)
Mitglied
RE: Problem with elastic filaments
Here are some general tipps and tricks: https://help.prusa3d.com/article/flexible-materials_2057
Veröffentlicht : 25/07/2025 12:14 pm
Pay particular attention to your idler pressure - on the page linked above.
Veröffentlicht : 25/07/2025 1:15 pm
Zwirbel
(@zwirbel)
Mitglied
Additionally, one tip, which is not described on the site above (I read this elsewhere): Use the standard nozzle and not the high flow nozzle.
Veröffentlicht : 25/07/2025 1:36 pm
amir faqihi
(@amir-faqihi)
Mitglied
I tried loosening the idler, but there are just screws placed at the outer side of the plastic cover which do not seem to affect the gears, or am i wrong with the assumption?
Diese r Beitrag wurde geändert Vor 11 months von amir faqihi
Veröffentlicht : 28/07/2025 7:07 pm
The Filament tension screws are on the top of the extruder (Red pointer)
the Green screws hold the gearbox together, the ilder swivel transfers the tension from the tension screws into the idler assembly, which presses the filament against the side of the outer gear on the planetary gear assembly inside the extruder gearbox.   causing the filament to move into the nozzle
I Hope this helps.
Veröffentlicht : 28/07/2025 7:40 pm
