Printing new fan door and loveboard cover/shroud - can I print these in PLA?
jbroggio
(@jbroggio)
Hello all,
I had to replace the fan on my mk4, and I found the wire routing to be a pain, so I redesigned the fan door and loveboard cover to make it less annoying to do that in the  future.
Do you think I can get by with printing those parts in PLA, as I have have orange PLA? Or do you think they'd sag and I need to use ASA (which I have, just not in orange) ?
Thank you!
Opublikowany : 20/02/2025 10:27 pm
jbroggio
(@jbroggio)
RE: Printing new fan door and loveboard cover/shroud - can I print these in PLA?
Never mind - I just realized that one part explicitly says "ASA recommended or similar" (the fan shroud), so I am guessing I am OK with PLA.
Opublikowany : 21/02/2025 3:50 am
Brian
(@brian-12)
I would do PETG minimum.  That's what the MK4 came stock with.  The 4S is PCCF.
Are you running in an enclosure?
Opublikowany : 21/02/2025 5:10 am
jbroggio
(@jbroggio)
yes - I am using the prusa enclosure.
Opublikowany : 21/02/2025 8:10 am
Brian
(@brian-12)
It needs to be PETG minimum then. PCCF, out ASA would be even better, but since they are just covers not 100% necessary.
Opublikowany : 21/02/2025 12:02 pm
