[Solved] Frustrating Layer shift on print
luggw1
(@luggw1)
I've been trying to print the attached knob and have been getting the layer shift shown in the photo.  I've printed this successfully, before upgrading the printer to a 4S and under an earlier slicer version, without problems.  This time I increased perimeters to 7 to give more strength around the screw hole, but made no other changes.
Any thoughts on how to prevent the layer shifts?
Thanks
Bill Lugg
Posted : 27/08/2025 2:34 pm
luggw1
(@luggw1)
FYI, here's my .3mf file and STL...
HTH
Bill Lugg
This post was modified 1 week ago by luggw1
Posted : 27/08/2025 2:35 pm
It's hard to tell from the picture but it looks like the shift occurred about the level of the start of the locator on the underside of the top - its possible that this was/is poorly supported and tipped to interfere with the head-travel.  Your filament is a little damp which won't help.
Consider designing a custom support for this area - say, two narrow towers with a single-layer bridge between them to support the start of the freely floating locator - it will be easy to snap away the support after printing.
Posted : 27/08/2025 9:48 pm
luggw1
(@luggw1)
RE: Frustrating Layer shift on print
I finally was able to revisit this problem.  I checked belt tensions with the belt tuner and actually found both the X and Y axis belts to be a bit too tight, so I fixed that and I lubed the X-axis rods lightly with Prusa's grease (the printer had set for at least couple of months unused).  I ran the print again this afternoon and it came out perfect.
Bill Lugg
Posted : 31/08/2025 4:25 am
