USB Stick filesystem damaged - fix
Marcel Benček
(@marcel-bencek)
If you run into problems with damaged USB stick filesystem you can do:
After sending a sliced object for print this appeared on the LCD and print files were missing and damaged. I put USB to PC (Win 11) and run Right click on USB Stick in File Explorer and Properties > Tools > Error checking > Check to fix the drive. File system was repaired, anyhow some files were permanently deleted but printing was possible again.
Questa discussione è stata modificata 11 months fa 2 tempo da Marcel Benček
Postato : 11/06/2025 7:36 am
