Updated to Firmware 6.5.3 (MK4S with MMU3) - MMU3 not working anymore
Dave Hammer
(@dave-hammer)
Hello guys,
I have installed the firmware:
  • MK4_MK4S_MK3.9_MK3.9S_firmware_6.5.3.bbf
  • with the MMU3_FW3.0.4+936.hex
(Downloaded in the offical PRISMA Firmware and Download section)
My Printer is an MK4S with MMU3, but after this Firmware update, my printer says, that the MMU3 is not compatible with the Firmware 6.5.3I did a hard firmware reset, problem still occures.
After that, I have installed the Firmware:
  • MK4_MK4S_MK3.9_MK3.9S_firmware_6.4.0.bbf
  • MMU3_FW3.0.3+896.hex
This works for me.
But, next day, it says: to much power onthe MMU 🙁
I did a hard reset again, with the 6.4.0.bbf and 896.hex - and works again.. maybe for more than one day.
I also checked all cables, but all seems fine.
Is there an older firmware version, I could download and use for my MK4S with MMU3?Just got lost in the GitHub Repo.
Thank you in advance!
Best regards,
David
Opublikowany : 06/05/2026 7:21 am
Borq
 Borq
(@borq-2)
RE: Updated to Firmware 6.5.3 (MK4S with MMU3) - MMU3 not working anymore
I experienced this too.
Solved by flashing this
https://github.com/prusa3d/Prusa-Firmware-MMU/releases
onto the MMU using this guide
https://help.prusa3d.com/article/how-to-update-firmware-mmu3_701584
! Beware you use a data ready micro usb (not all loading cables are!!) otherwise it wont show in the flash software
Opublikowany : 08/05/2026 11:21 am
1 ludzie polubili
