Replacing broken Rotary Encoder on xLCD
Marchrom
(@marchrom)
Hello,
I have a Prusa MK4S and somehow i managed to break of the Rotary encoder (Knob) on the xLcd. sadly i cant just glue it back, but also other than the knob the board still works fine, so i would like to just replace the Rotary encoder myself instead of buying a new Board.
So i have been searching for the exact model of the Rotary encoder to buy a replacement, but i can't seem to find the exact model or any documentation for the board.
From what i have found it seems to be some Variant of a EC11 (SMD rotary encoder with push button). But no model i have looked at has this sort of step in the barrel below the shaft.
I haven't desolderd the part yet, so i don't know if maybe there is a part number on the underside of the encoder and i haven't measured the pins yet, so i am not 100% sure if the EC11 Variants are fully compatible.
Can anyone help me find the exact model or a fitting replacement for this part?
kind regards ^^
Napsal : 30/03/2026 11:32 am
The schematic specifies an ALPS EC11J1524413. Does this look right?
Napsal : 30/03/2026 1:35 pm
1 lidem se líbí
jan.d.slay
(@jan-d-slay)
RE: Replacing broken Rotary Encoder on xLCD
AI search task.
"Hello,
Based on what we currently know, the encoder on the Prusa xLCD is most likely an ALPS Alpine EC11J1524413 and not just any random EC11 variant.
Prusa does publish the xLCD schematics for the MK4/MK4S, but no BOM/parts list with all individual components. That’s why the encoder doesn’t appear directly as a replacement part in the official documentation—officially, only the complete xLCD board is sold.
However, the specifications for the EC11J1524413 match very well: SMD, with pushbutton, D-flat wave, 30 detents / 15 PPR, 5 V. That is exactly why I would not order a generic EC11, but first look for this specific type.
Before ordering, I would still compare the footprint, waveform, and height with the desoldered original, because there are different versions of the Prusa xLCD.
If the ALPS type is no longer readily available, a mechanically and electrically compatible replacement might work. For example, a Same Sky RIC11-31S10K3-GSMT has already been successfully used as a replacement for a similar Prusa encoder on the Prusa forum.
In short: Yes, your EC11 guess is close—but the specific match is very likely the EC11J1524413."
Napsal : 30/03/2026 1:47 pm
Marchrom
(@marchrom)
this looks like a good fit, thank you so much for the help!!
Napsal : 30/03/2026 1:53 pm
1 lidem se líbí
As an afterthought: This may be a tricky desoldering and/or soldering exercise. With the LCD right next to the encoder, I would be reluctant to blast the part with hot air for desoldering. Maybe you can detach the LCD from the PCB to swivel it out of the way? (I believe it is attached with adhesive tape?) Or cut all the encoder's pins with side cutters if they are accessible, and unsolder the leftovers individually with a conventional iron.
In which way has the encoder been damaged? It is not fully torn off the board obviously -- but have some pads been torn off? (If so, do you have a plan how to re-establish the connection?) Is there mechanical damage to the part itself, like a bent shaft?
If you feel confident with this type of repair, of course please go ahead. Otherwise feel free to post further details, maybe a photo, so we can jointly figure out the best course of action.
Napsal : 30/03/2026 2:32 pm
Marchrom
(@marchrom)
you raise a good point there.
the part that broke is the barrel (i don't know if there is another name for it) that holds the shaft on the actual encoder.
i don't know how difficult it will be to replace, but i do have access to a good soldering equipment and a vew very capable friends.
the old part is useless now anyway, so if possible i might try cutting of the old part at the legs first, then cleaning the soldering pads individually and then resoldering the new part.
if this doesn't work i might try getting the lcd out the way and then using hot air soldering to remove it
thanks for the help tho!
i might give an update if i'm successfull so maybe it can help other people.
i'll have to order the part first tho, so it might take some time
Napsal : 30/03/2026 2:45 pm
1 lidem se líbí
