PETG problems
Poul-Erik Hagemann
(@poul-erik-hagemann)
PETG problems
https://photos.google.com/photo/AF1QipP636Y_xqeEQiUlRjO9HusctUAlILX51ehG4Zwk
https://photos.app.goo.gl/sfFgW56uZnJdy1M49
First layer quite ok, but then it starts to make a lot of troubles.. Any ideas.  Filament PM PETG, 15 % moist  Sometimes on 3.rd. layer, sometimes infill.. Whats wrong?
This topic was modified 10 months ago 2 times by Poul-Erik Hagemann
Posted : 17/01/2025 10:01 am
Pictures hidden behind log-in wall.  Please post them here (Add Media) for inspection.  Dry your filament and try reprinting first...
For more detailed analysis save your project as a .3mf file
Files > Save Project as
Posted : 17/01/2025 12:34 pm
Poul-Erik Hagemann
RE: PETG problems
Thx, i'll try to get the pictures uploaded
Posted : 17/01/2025 3:19 pm
Poul-Erik Hagemann
First layer is looking fine
This post was modified 10 months ago by Poul-Erik Hagemann
Posted : 17/01/2025 3:20 pm
Brian
(@brian-12)
RE: PETG problems
Looks like underextrusion, raise nozzle temp 10 degrees.
Posted : 17/01/2025 8:27 pm
What is the profile in the lower layers?  Please supply the zipped .3mf as above.
Posted : 17/01/2025 8:52 pm
Poul-Erik Hagemann
Ohh, forgot the file..sry.
Here it is. (Hope it works, having trouble attaching)
This post was modified 10 months ago 2 times by Poul-Erik Hagemann
Posted : 18/01/2025 8:32 am
RE: PETG problems
the project file must be ZIP compressed
Posted : 18/01/2025 9:50 am
Poul-Erik Hagemann
RE: PETG problems
It is, but seems like it does'nt get accepted when pressing save.
Posted : 18/01/2025 10:06 am
RE: PETG problems
That is very odd...
Joan
Posted : 18/01/2025 10:09 am
Poul-Erik Hagemann
RE: PETG problems
Yes, I also find it a bit odd.
Regards
Poul Erik
Posted : 18/01/2025 10:41 am
Poul-Erik Hagemann
RE: PETG problems
One more try with the zip
Posted : 18/01/2025 10:47 am
I don't use HF nozzles so I can't comment on profiles for them 'though I doubt you'd see much difference for small parts like that.
The odd perimeter adhesion *might* be reduced by a thorough print-sheet clean, and reducing/disabling your elephant's foot compensation might improve the edges too - and replace the grid infill with cubic 'though your print hadn't got that far...
The temperature increase @brian-12 suggests might also help although stepping up 5° at a time would be my approach.
Posted : 18/01/2025 1:13 pm
Brian
(@brian-12)
RE: PETG problems
I'm not near my computer till later tonight, but you should be running around 250° C for PETG with 240 for the first layer.  The Prusament profile is pretty much spot on.
I think like 70% of problems with the MK4S is that people use old filament profiles or the generic Prusa profile which isn't hot enough for the speeds the 4S runs.  That's why typically the first layer prints ok and when the speeds pick up the issues start.
The other option if you didn't want to run hotter is to lower the volumetric flow rate in the filament profile.  For whatever reason many people are scared to turn the temperatures up.
Posted : 18/01/2025 2:39 pm
Ineal
(@ineal)
RE: PETG problems
if i got get the wrong filament while open or is on this file "politeria PLA" used?
so i think the Problem is wrong slicer setting on Filament.
Posted : 18/01/2025 4:21 pm
Poul-Erik Hagemann
RE: PETG problems
Thx a lot. I'll give it a try with a bit higher temp.
Posted : 18/01/2025 9:58 pm
