Nozzle Rubbing Solid Infill on larger print
Mizzoudavis
(@mizzoudavis)
I'm printing a file that is basically a flat plate, covering most of the print surface. It's 20mm tall. On the solid infill layers, the nozzle begins to rub on the print and I get a 'stuck filament' error. I've read this post about changing the infill to gyroid but I got the same error. I also made the print shorter (10mm) and I get the same issue. Smaller prints are just fine and all the other layers print as expected. It's just the solid infill above the gyroid infil (I haven't gotten to the 'top solid infill' layer yet so I'm being pedantic about 'solid infill' ).
Anyone experienced this?
Napsal : 24/03/2025 11:38 am
