MK4S xLCD not detecting USB
FireBlast2.0
(@fireblast2-0)
Hello,
I've recently encountered an issue with the xLCD and the xLCD cable, every time the cable is tapped or slightly moved the USB stops being detected, Ive tried many times to solve this, at first I thought the issue was caused by a corrupt USB drive but I formatted it and re hardware programmed the USB yet still getting the same issue.
Should I just buy a new xLCD cable?
Opublikowany : 18/05/2025 9:07 pm
