MK4S tension in back of y axis causes failed homes
Watrmeln
(@watrmeln)
IMG_2155
i recently reseated the y belt after the tensioner came off, and after attempting a print, it infinitely jams the y axis, maybe due to some tension in the back or due to the moving belt? i'm not sure what happened here.
Publié : 28/08/2025 6:51 pm
Watrmeln
(@watrmeln)
RE: MK4S tension in back of y axis causes failed homes
^ i should add i reseated the belt due to the tensioner being too loose and causing huge layershifts
Publié : 28/08/2025 7:00 pm
Watrmeln
(@watrmeln)
IMG_2157
update: after i updated the firmware to the new RC build this happened and now the issue seems to have gone away on its own.
i love 3d printing 🥲
Publié : 28/08/2025 10:25 pm
Watrmeln
(@watrmeln)
apologies for so many replies in a row, but it's now layershifting. It always happens when i'm doing something else so i have no footage
Publié : 29/08/2025 4:34 pm
Watrmeln
(@watrmeln)
after a bit, i've discovered that the belt is too far to the right, and i believe that the holder at the bottom of the plate may be knocking into the metal. it's also making a squeaking sound.
Publié : 15/11/2025 6:39 pm
darkmattermaker
(@darkmattermaker)
Your belt is way skewed. It should be nicely aligned top/bottom. The bottom should not be sticking out that far. I'd recommend going through the Y-axis belt installation instructions in the build guide and make sure everything is together correctly:
https://help.prusa3d.com/guide/7-y-carriage-heatbed-assembly_707785#719559
Specifically, step 32 which covers aligning the belt: https://help.prusa3d.com/guide/7-y-carriage-heatbed-assembly_707785#719958
Publié : 16/11/2025 3:43 am
Watrmeln
(@watrmeln)
turns out i had the little corrugated piece on the motor on backwards.... i've corrected it so i'm gonna see how it works
Publié : 16/11/2025 11:51 am
1 personnes ont aimé
