MK4S Homing Behavior with Firmware 6.1.3?
ScottW
(@scottw)
The homing behavior (G28 or via LCD "Auto Home") has changed a bit with various firmware versions, particularly as regards how many times the X and Y axis "bump" into their limits to determine the X=0 and Y=0 points.  After upgrading to MK4S and firmware 6.1.3, I am seeing a new behavior and just wonder if it is typical.
I will describe what I am experiencing.
  • For the first G28 or Auto-Home after power-on:  The x-axis bumps 18 times on the left side, then the y-axis bumps 18 times at the rear.
  • For all successive G28 or Auto-Home (until the next power-off), the x-axis bumps 2 times on the left side, then the y-axis bumps 2 times at the rear.
That behavior (18 bumps on first homing after power up, 2 bumps on all others) is consistent for me.  Homing completes without error and proceeds to Z homing (2 taps on plate).  Belt tension is good, X and Y move smoothly, and there are no obstructions.   I even did a full "factory reset", went through all calibrations again, and still have the same behavior.
Is this "18 bumps" for first homing of X and Y typical with MK4s and firmware 6.1.3?  What are others seeing?
Posted : 12/10/2024 11:35 pm
RE: MK4S Homing Behavior with Firmware 6.1.3?
I didn't count the number of bumps but it's definitely a lot more than it used to be.
Posted : 15/10/2024 1:23 am
MarkusRe
(@markusre)
Sounds like this reported firmware issue https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4185
Posted : 15/10/2024 7:37 am
ScottW
(@scottw)
Posted by: @markusre
Thanks, I saw that report and it does seem similar, so maybe it is the same issue. But what I am seeing is very consistent (always 18 "bumps", X and Y, and only on first print), whereas the discussion there includes a lot of variation.  Maybe it is one issue and just behaves a little differently across different printers.
If everyone (with MK4/MK4S and 6.1.3) is seeing it, I am surprised there hasn't been any discussion here on the forums.
Posted : 15/10/2024 3:38 pm
PanicCarefully
(@paniccarefully)
My two MK4 experience the same above mentioned behaviour before the very first print, after startup.
If anyone does have a clue, I would be very happy.
Thank you!
Posted : 28/10/2024 8:20 pm
pa1ntman
(@pa1ntman)
Same here. Right after  starting up. Bangs like crazy in both axis. Mk4 6.1.3
Posted : 29/10/2024 1:53 pm
pa1ntman
(@pa1ntman)
Wonder if anyone is getting anywhere with this? Really annoying, yesterday it was banging away and suddenly reported a printer ‘collision with a red screen then cleared the message and went to work, this can’t be good for the unit?
Posted : 08/11/2024 10:58 am
chmax
(@chmax)
same. Does anybody "out there" experience the same with the beta fw 6.2?
Posted : 14/11/2024 10:39 am
 No change on my 2 systems running 6.2.
Posted : 14/11/2024 10:49 am
pa1ntman
(@pa1ntman)
By no change I assume you mean it’s still banging away?
Posted : 14/11/2024 10:51 am
Happily banging away indeed.
Posted : 14/11/2024 11:23 am
iftibashir
(@iftibashir)
I counted mine - also exactly 18 bumps on both axis........
Posted : 18/11/2024 10:31 am
Stefan
(@stefan-18)
I like Prusa, but it is a real pain that they seem to simply ignore this nagging problem.
Posted : 25/11/2024 12:31 am
