[Resuelto] Mk4s calibration dot on printing plate
SmalLabs.net
(@smallabs-net)
hi all,
Today I noticed points where the calibration ruined the printing plate after 10 perfect print .
Este debate ha sido modificado el hace 2 years 2 veces por SmalLabs.net
Respondido : 21/08/2024 7:45 pm
carmamir
(@carmamir)
RE: Mk4s calibration dot on printing plate
I have tried to lower the nozzle temp during bed calibration. Using 140 now (same as on my X1c's)
Respondido : 22/08/2024 10:16 am
fabnavigator
(@fabnavigator)
If your nozzle isn't clean, or is oozing some, you can end up with little blobs of filament on the build plate. You should be able to clean them off.
If you are referring to the tiny marks that are due to the nozzle touching the build plate, I can't say from the picture that the build plate is ruined. I will say that you might be better served using the satin build plate. It is much more forgiving.
Respondido : 22/08/2024 11:23 am
SmalLabs.net
(@smallabs-net)
I printed on it and they came away 😀
Respondido : 22/08/2024 1:24 pm
1 les gusta
