[Risolto] Loadcell issue MK4S/MMU3/High flow nozzle
Ron
 Ron
(@ron-10)
I got the following:
Failing loadcell test (and related failing Z-axzs test).
Just before failing the test, when starting a the print, the nozzle cleaning was pushing very hard in the print plate. plate is damaged.
After seeing this I stopted the started print.
Then I got the loadcell test that didn't work anymore (no reaction when tapping on the nozzle). Looking in the sensor info the value of the loadcell is 0.0 and when I disconnect the loadcell from the extruder board, I see in the sensor value is continuous changing. Plugin in the senior again, it comes back to 0.0
I suppose the Loadcell is broken ? Any suggestions please ?
IMG_3567 IMG_3568
Regards, Ron
Postato : 14/05/2025 8:20 am
Ron
 Ron
(@ron-10)
RE: Loadcell issue MK4S/MMU3/High flow nozzle
Update:
Prusa support confirms the loadcell is broken. It will be replaced.
thanks to the support team.
topic closed
Regards, Ron
Postato : 14/05/2025 1:28 pm
