Compiling Source for the MK4S
Audioguy140
(@audioguy140)
Membre
Hello All,
I was wondering if anyone here has tried compiling the source for the MK4S? As I understand it, the MK4S is the MK4 with some updates. Before I go and "break the apendix" (break appendix doc) I would like to confirm the MK4 option is the option to pick for the MK4S, when building the Buddy Board firmware from Source.  My overall goal is to customize the LED color/s on the GUI display assembly. Any feedback from other users experience when building source would be appreciated.
Publié : 25/08/2024 1:57 pm
Audioguy140
(@audioguy140)
Membre
Hello All,
I wanted to provide an update on my progress:
I was able to build the MK4 firmware using VScode on a raspberry pi5 as it is the only linux box I have lying around. I wouldn’t recommend tying to build on another platform. Most linux distros have all the tools needed to build by default. It appears that windows and mac need to run some extra scripts/downloads etc to build the code.
Once I had the code built, I loaded one of the bff files onto a USB stick.
SIDE NOTE: Ktpanda has done some nice work documenting the output of the builds in another forum:
https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-hardware-firmware-and-software-help/custom-firmware-installation-on-mk4-_boot-bbf-or-_noboot-bbf/
“mk4_release_noboot.bbf is for running the firmware straight on the processor, without a bootloader present. I don't think this is useful to many users unless you have your own custom board.
mk4_release_boot.bbf is for running the firmware from the bootloader, and contains a bootloader image which will be flashed alongside it. The image is not built from the Prusa-Buddy-Firmware repo and is just a binary blob downloaded from Prusa's Amazon S3 bucket.
mk4_release_emptyboot.bbf is also for running the firmware from the bootloader, but does not contain the bootloader image. This is the one that ended up working for me. It is not built by default -- you have to pass --bootloader empty to build.py to get it.”
I followed the directions in this post to use a custom build on the Buddy board:
https://help.prusa3d.com/article/flashing-custom-firmware-mini_14
I proceeded to update my printer using the USB stick and received a “red screen” with an error code on it. ERROR 13612:
https://help.prusa3d.com/article/no-fw-in-internal-flash-26612-mk4s-13612-mk4-21612-mk3-9-23612-mk3-5_401149
I didn’t know what this meant at the time, and I didn’t bother to look at the link, so I proceeded to solder a debug header onto my Prusa buddy board and use the ST tools to erase the flash on the microcontroller:
https://www.st.com/en/development-tools/stm32cubeprog.html
https://www.st.com/en/development-tools/st-link-v2.html
I tried to flash the some of the bin files that were produced by my build, but nothing seemed to work. I was able to get a white bar on the screen with one of the bin files, but that was as much progress as I was able to achieve. Having written some bootloaders myself I understood that the bootloader sits in low flash and the application sits above the bootloader on the ST processor so I decided to try and find the OEM bootloader as my machine was essentially “bricked”. I was able to download the bootloader from the s3 bucket ktpanda was speaking of in their post. Looking in the source files there is a file called bootstap.py that fetches certain assets during the build:
Prusa-Firmware-Buddy-6.1.2 -> util -> bootstrap.py -> 'bootloader-mk4'
The path to a zip file is listed in the source.
Using the ST tools listed above I was able to reflash the OEM bootloader and update my machine to the official released 6.1.2 version of firmware.
I will continue to document my experience and progress in building the code from source. The debug port is shown in the picture attached and circled in red.Debug Port
Publié : 26/08/2024 12:15 pm
1 personnes ont aimé
Audioguy140
(@audioguy140)
Membre
RE: Compiling Source for the MK4S
Hello All,
 An update on compiling source. This afternoon I was able to compile the source code and modify the LED color as I intended to do at the beginning of this task.
My first step was to use the ST tools noted above to backup a .bin file currently running on the STM32 processor. This would allow me to quickly recover the printer should I brick the unit again as I did before.
As noted above I used a Raspberry pi 5 with VScode installed to clone the Prusa-Firmware-Buddy repo. Once successfully built, several files are generated in the “build->products” folder in the file tree of the project. The file that I used to update my printer was mk4_release_boot.bbf.
The command I used to build is below. The options are documented in the README.md file of the repo:
python utils/build.py --preset mk4 --build-type release --generate-bbf
When building make sure you have the latest “tag” checked out. I was targeting v6.1.2 as it was recently released. I appreciate Prusa’a commitment to open-source information and love my new MK4S.When loading the "custom" firmware, I used the standard USB method documented throughout Prusa's help guides.
 I hope this thread helps others in the future.
Publié : 26/08/2024 10:19 pm
2 personnes ont aimé
LarGriff
(@largriff)
I’m still not able to successfully compile under windows.  It gets halfway then errors with something about not being able to get requirements to build wheel.  I was trying to build the latest release 6.2.2.  There is a more recent 6.2.3.RC available.  Should I try to build that instead?
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Publié : 18/03/2025 6:16 am
Audioguy140
(@audioguy140)
Membre
Make sure you follow all steps in the readme. Posting your build log would help 🙂
but it sounds like you just have missing dependencies.
RC stands for release candidate but it will probably depend on the same packages your current development environment is complaining about.
Publié : 18/03/2025 11:06 am
LarGriff
(@largriff)
Thanks for the help.  I hope this screenshot will make sense...
Publié : 18/03/2025 4:43 pm
Audioguy140
(@audioguy140)
Membre
It looks like it's failing because the build requirements are not being met. Make sure your development environment has all the needed python packages installed:
https://github.com/prusa3d/Prusa-Firmware-Buddy/blob/v6.2.3-RC/requirements.txt
Looks like there are 17 of them
Publié : 18/03/2025 5:07 pm
miroslav.h4
(@miroslav-h4)
When we talk about building and compiling FW for MK4. I only tried to translate the FW downloaded from Github without any modifications. The build failed. I used the command to build:  python utils/build.py --preset MK4 2> errors.txt 1> out.txt. How it turned out is captured in the attached file. There are two files in the zip: Out.txt is stdout from the command, and the errors.txt file captures the error output of the command. Can someone more professionally knowledgeable take a look at it and tell me where I'm making a mistake?
I also asked in the next thread about MK4. I hope the moderators won't scold me too much.
Publié : 19/03/2025 5:06 pm
