Will my existing MK4 bgcode files run on the MK4S and or the PRUSA CORE ONE?
kevin1954
(@kevin1954)
I have 200+ existing MK4 bgcode files (I have a print farm).
I need to add new printers, MK4S, PRUSA CORE ONE.
I need to be able to have ONE file which will run EXACTLY THE SAME on any of the 3 printers.
Thank you for you responses!
Opublikowany : 05/02/2025 2:11 pm
LarGriff
(@largriff)
RE: Will my existing MK4 bgcode files run on the MK4S and or the PRUSA CORE ONE?
Good question, I’m surprised no one else has replied.  My understanding (guess) is the bgcodes will *probably* run the same unless you’ve added some unusual custom gcodes. Fan efficiency might make a difference, but who knows?  Would be nice if you could get access to try ptrinting some of your files on those machines.  I’ve got a Mk4s, if that helps.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Opublikowany : 20/02/2025 6:55 pm
kevin1954
(@kevin1954)
I just got a new MK4s, still in the box (assembled).
I will be giving it a try in the next few days.
I did order a "standard nozzle" so I can  change out the High Flow nozzle if needed.
And I assume I could print the MK4 style fan and basically be the same unit.
I will post results in a few days.
Thanks for you input.
Opublikowany : 20/02/2025 7:16 pm
1 ludzie polubili
SushiSushiSushi
(@sushisushisushi)
Kevin, what was the verdict?
Opublikowany : 04/05/2025 11:22 pm
Diabolical Terrain
(@diabolical-terrain)
Just (today) finished the build and added a MK4S to my stable of Mk4 printers, and stumbled across this post wondering the same.  Both iterations of printers are running stock hardware.
I can report with 100% certainty that files sliced for my MK4 printers work just fine on the MK4S.
The 4S throws an initial warning, however simply click the PRINT option to bypass and it does just fine.
Posted by: @sushisushisushi
This post was modified 10 months temu 2 times by Diabolical Terrain
Opublikowany : 05/07/2025 2:03 am
