Thumb drive for MK4s
Beebad
(@beebad)
I wanted to. Replace the protruding prusa thumb drive with a low profile one.
will any drive work?
Opublikowany : 24/08/2025 4:31 am
SweetRide
(@sweetride)
RE: Thumb drive for MK4s
I would recommend a name brand drive. I think the formatting has to be FAT32.
I originally had issues with larger than 32 GB drives because of the formatting. This may have since changed, but keep in mind.
I personally use one of these....  https://www.walmart.com/ip/SanDisk-32-GB-Cruzer-Fit-USB-Flash-Drive-SDCZ33-032G-A46/22274661?wmlspartner=wlpa&selectedSellerId=101587783
Opublikowany : 25/08/2025 11:29 am
Beebad
(@beebad)
Thank you! Just so happens I ordered a mini usb thumb drive last night. I hope the 64gb will be ok. It is really small!         https://a.co/d/gmTPqMj
I think most drives are fat32 because it is more universal but is shouldn't be too hard to reformat.  Will a blank drive repopulate from my inline prusa storage?
Opublikowany : 25/08/2025 12:08 pm
GalFisk
(@galfisk)
Windows won't format bigger drives than 32GB to FAT32, but I've heard that there exist workarounds. Perhaps Rufus can do that? (Yes, I googled it, and it seems that way. Select "large FAT32").
But you don't really need a bigger drive anyway.
Opublikowany : 25/08/2025 3:35 pm
Beebad
(@beebad)
Thanks, i cancelled rhe order and hot the 32gb. Thanks
Opublikowany : 25/08/2025 10:58 pm
Beebad
(@beebad)
i got the 32gb mini thumb today, transferred everything from OEM thumb, everything works. The thumb stays on the printer.
Opublikowany : 27/08/2025 4:18 am
1 ludzie polubili
