Gcode not compatible error
3dtony
(@3dtony)
Miembro
having just finished upggrading to 4s i have had numerous error messages thrown up by prusa slicer and the printer firmware I have managed to clear most of them but cannot get rid of "gcode not comppatible" which seems odd as it was sliced by prusaslicer! If i choose to override the warning and print anyway it prints fine. Has anaybody else this problem?
Respondido : 13/09/2024 10:14 am
TeamD3dp
(@teamd3dp)
RE: Gcode not compatible error
I would assume this has to do with the selected printer profile or presets indicating Mk4 when the printer firmware is saying Mk4S.  I would double check all of your slicer settings and make sure the presets and names of your physical printer have been updated.  I didn't have a problem when I upgraded mine, but I DID get that message when I tried sending a model from Orca Slicer and assumed it was because there isn't yet an Mk4S profile there and the printer name remains Mk4.  I somewhat wonder if this is a very simplistic printer name check for people with multiple types of Prusa's, and is simply to make sure you're not sending Mk4 jobs to a Mini, for example.  This is just a guess though, as I haven't specifically tested this.
Respondido : 17/09/2024 1:21 pm
Studer Austria GmbH
(@studer-austria-gmbh)
It's quite simple and caused by the hardware setting of the Mk4 . you have to change the hardware settings in the printers menu ( not the slicer) from MK4 to Mk4S .
Respondido : 26/09/2024 9:02 pm
3dtony
(@3dtony)
Miembro
Thanks to all for the tips currently away from “farm” will have a delve into the firmware when I return
Respondido : 26/09/2024 10:26 pm
Bobster
(@bobster)
I only just had this error, your solution worked first time. Thankyou.
Respondido : 17/04/2025 9:55 am
avrorafrix
(@avrorafrix)
Miembro
You're not alone — I've seen a few people mention the same issue after upgrading. It’s odd when it prints fine but still throws up warnings; definitely feels like something minor between slicer settings and firmware versions.
Respondido : 27/04/2025 12:16 pm
nfa-prusa
(@nfa-prusa)
Miembro
Hopefully this saves time for someone who is in a similar situtation as I was. I have the MK4S with mmu3. The issue I had was that the mmu3 unit somehow got disabled in settings. I had to reenable by Settings > MMU Unit (toggle to enabled), and everything worked fine.
Unfortunately before I thought to check that, I followed some weird rabbit holes.
Respondido : 01/12/2025 3:38 pm
