Print Fan blower case screw hole alignment - off for left top hole.
I've come to realize that on the left side of the Print Fan blower case, only one screw (the bottom) engages fully with the nut I inserted. The other hole is misaligned with the hole in the case. This has been causing the occasional scraping I've seen with the shroud, because it sits too low. I've managed to get the top screw to go in partially, and now the case is held up properly, but it's ugly.
I would appreciate thoughts on whether it more likely I am seeing a problem with the drilled holes in the case (in which case I can either buy or print another) or with the metal frame that holds the blower fan (in which case I will want a corrected one from Prusa)? I don't have the frame upside down, etc. These I've checked.
Thanks.
Posted : 11/10/2024 11:28 am
