Print Failures
marckon
(@marckon)
Mitglied
Print Failures
I just started 3D printing with a MK4S which I assembled myself. Please see one of my first prints attached. There are two models. It looks like for each model, the quality gets worse in the top right corner. Also, it looks uneven for the most part for the filled piece.
I’d appreciate any advice or explanation what might be the issue.
Thank you,
Marc
Veröffentlicht : 22/12/2024 3:54 am
kenb
 kenb
(@kenb-2)
RE: Print Failures
I'm having similar/same problem with a MK4 upgraded to MK4s.  This is printed with Prusa filament, using the standard slicer selections (0.20mm STRUCTURAL) other than 20% infill and adaptive cubic as the infill type.  Prusaslicer v 2.8.1 on a mac.
I've also had this problem with other filaments that require lower temps and I corrected those by reducing the flow rate 5% or thereabouts and the speed to 70-75%. After that, no problems.  This time since I was using Prusa filament, I left everything standard since this always worked with the MK4 before the upgrade.
How can I fix this?
Thanks
kb
Veröffentlicht : 31/12/2024 12:59 am
