MK4S with MMU3 filament tangling with suggested set up
Hi! I am using my new MK4S with MMu3 printer and during the test print an every print since the filament begins tangling after 3 or 4 filament changes. If I sit with the printer and rewind the filament after each change, I can make it through a print, but that's obviously not idea. I have an enclosure I plan to put on it as well, I just wanted to get the thing working consistently before I do that. Any suggestions on better options for buffering the filament? Thanks!
Veröffentlicht : 08/08/2025 9:22 pm
RE: MK4S with MMU3 filament tangling with suggested set up
I would go with the recommended option to use the filament buffer by Prusa.
Veröffentlicht : 11/08/2025 10:01 am
