MK4S - Do I need to swap to non-HF nozzles for the structural presets?
Azxiana
(@azxiana)
I noticed that the structural profiles do not have "HF" for the nozzle size.  Do I need to switch to a regular nozzle when using the structural presets on the MK4S?
For context I just set this MK4S up next to a MK4 that will also be upgraded to a MK4S.  I normally print using the "0.15mm Structural @MK4IS 0.4" input shaper preset.
Napsal : 12/12/2024 12:52 pm
carlmmii
(@carlmmii)
RE: MK4S - Do I need to swap to non-HF nozzles for the structural presets?
No. The speeds that the structural presets are limited to come nowhere near close to what the HF nozzle can take advantage of, so there's no point to have a separate profile. Just use the HF nozzle with the regular structural profile.
Napsal : 14/12/2024 10:41 am
LarGriff
(@largriff)
Run the configuration again and choose the nozzles you need to go with your chosen printer.  Then they’ll be available in the slicer.
Cheers!
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Napsal : 28/12/2024 2:31 pm
