G-code is not fully comatible
Markus D.
(@markus-d)
Hello, I am new in the Prusa world. My MK4S is doing fine, but he gives me this message always before printing: " the G-code is not fully compatible- printer model doesn't match -fan speed will be reduced". And then it prints perfectly! I draw all the stuff in Rhino 3D, exported them as stl and created the G-code in Prusa slicer for the right printer model. Is this just an irrelevant bug of the printer, or did I make a mistake here.
Veröffentlicht : 24/09/2024 10:35 am
steve457
(@steve457)
RE: G-code is not fully comatible
Two things to check:
1. Make sure you sliced your code using the MK4S printer profile
2. On your printer make sure it is set to a MK4S, Settings->Hardware->Printer
My guess is your printer is set to a regular MK4 in the settings, as I got that same error when mine was after I upgraded.
Veröffentlicht : 24/09/2024 8:22 pm
Markus D.
(@markus-d)
all the g-codes the slicer created are for the MK4S printer and the settings on the printer are correct too.
Veröffentlicht : 25/09/2024 4:35 pm
DonP
 DonP
(@donp-2)
Mitglied
In PrusaSlicer under Printers menu/Custom G-code/Start G-code the third line should read:
M862.3 P "MK4S" ; printer model check
Mine was set to just "MK4" and I was getting the G-code is not fully compatible warning. I add the "S" and the warning went away.
Veröffentlicht : 24/12/2024 2:26 am
DeepOrange
(@deeporange)
Mitglied
I tried this and it worked for me too.
But is this the right thing to do?
When using the normal profile the custom G-code is: M862.3 P "[printer_model]" ; printer model check. So I presume it reads the printer model from somewhere.
When using the Input Shaper profile, the G-code is: M862.3 P "MK4" ; printer model check. So it is pre-set to Mk4.
You cant save over a system profile, so to keep it there you need to save a copy with a differnet name and remember to activate that profile.
Surely it cant be right?
Veröffentlicht : 29/12/2024 11:56 am
