Change nozzle MK4S
norm
 norm
(@norm-2)
Change nozzle MK4S
Can anyone please point me in the direction of an updated video explaining how to change the nozzle for the mk4s using the printable tool.
Everything I can find is for older printers. I’d like a guide or solution that lets me switch the nozzle without having to dismantle the surrounding enclosure, remove fans etc.
Napsal : 02/01/2025 9:11 pm
2 lidem se líbí
RE: Change nozzle MK4S
https://help.prusa3d.com/guide/how-to-replace-the-prusa-nozzle-mk4s-mk3-9s_734750
Napsal : 03/01/2025 3:42 pm
2 lidem se líbí
UjinDesign
(@ujindesign)
I have the MK4 (not the MK4S) and when I change nozzles I never disconnect the power cables. I just loosen the holding screws and unscrew the nozzle. And then rescrew the nozzle and tighten the holding screws. Takes like 20 seconds. I assume the same is possible with the MK4S!
Napsal : 03/01/2025 9:29 pm
1 lidem se líbí
norm
 norm
(@norm-2)
Do you use the printable part mentioned in the link above?
Napsal : 04/01/2025 1:12 pm
Walter Layher
(@walter-layher)
Something like this is a big help too: https://www.amazon.de/gp/product/B092369RYR
Napsal : 04/01/2025 4:12 pm
1 lidem se líbí
Cassolotl
(@cassolotl)
I would also really love to see a guide with photos for changing the nozzle using the Nozzle Replacement Tool with the MK4S. I can't work out how to remove the fan on the front, I can't see what I'm doing or where to put the tool, etc.
Napsal : 24/02/2026 10:24 pm
1 lidem se líbí
Posted by: @cassolotl
You don’t remove the fan, just insert the tool over the heat break, loosen the thumb screws and unscrew the nozzle.
Napsal : 26/02/2026 11:53 am
Cassolotl
(@cassolotl)
Posted by: @hyiger
Right, this is why I need a photo guide - I don't know what any of those things are! (I'm not asking for an explanation here, it's okay. My current peril is here.)
Napsal : 26/02/2026 12:16 pm
Walter Layher
(@walter-layher)
The tool should be inserted on to the hotend like this. I use the no-sock version of the tool and remove the silicon sock before changing nozzles, because it has a better fit. Then I hold the tool with one hand from below to prevent the tool and the hotend from dropping and unscrew the nozzle with a small socket wrench tool or a torque wrench with the other hand.
Napsal : 26/02/2026 12:38 pm
3 lidem se líbí
Cassolotl
(@cassolotl)
Ahhh thank you, this is really helpful! I tried with the sock version and now my printer is behaving strangely, so I will print the no-sock version at my local makerspace and try again using your photos as a guide.
Napsal : 26/02/2026 1:31 pm
