GIPO - Canon EOS R8 - 2.5mm
Seite 1 / 3
512MB
(@512mb)
How can I configure my Prusa MK4S with the GPIO board to trigger a camera and take a picture right after each layer change? The camera uses a 2.5 mm AUX input, and I currently use a microswitch on another printer to trigger it. I’d like to switch to using the GPIO functionality on the MK4S instead. How can I achieve this, and what G-code or methods are recommended?
Best Answer by Zemistr:
I am just checking the Canon R8.
Cable Jack 2.5 mm to Jack 2.5 mm is just plug and play.
The pins in the open drain section are not able to send any current to nowhere.
They are basically just connecting pin from the open drain section to the GND.
Use M262 P0 B0 to set the pin 0 as output.
Use M264 P0 B1 to connect the pin 0 to GND.
Use G4 P200 to wait 200ms.
Use M264 P0 B0 to disconnect the pin 0 from GND.
So the whole G-Code is:
M262 P0 B0
M264 P0 B1
G4 P200
M264 P0 B0
Btw... I am using Canon R5C... 😅
Veröffentlicht : 25/01/2025 2:03 pm
LarGriff
(@largriff)
RE: GIPO - Canon EOS R8 - 2.5mm
Try the following post.  He demonstrates triggering a cellphone to take stop-motion pictures.  It should be somewhat similar to what yay need.
https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-add-ons/youtube-videos-using-prusa-gpio-hackerboard/#post-733740
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Veröffentlicht : 25/01/2025 3:00 pm
512MB
(@512mb)
When I first read it and watched the video, it became clear that this wasn’t a simple solution. Disappointing.
Veröffentlicht : 25/01/2025 4:05 pm
LarGriff
(@largriff)
Your situation should be quite a bit simpler using your Canon camera.  You’ll just need the GPIO board.  You probably wont even have to do any soldering if you already have a shutter release cable.  Just plug it in to the GPIO board and setup the gcode to use pin 0 as an output per the video.
Veröffentlicht : 25/01/2025 4:26 pm
512MB
(@512mb)
The cable used to take a picture is a standard 2.5mm AUX cable. From what you’re saying, I simply need to plug one end into the AUX port on the GPIO board and the other end into the camera’s 2.5mm AUX input.
After that, I should call M262 P0 B0 to set pin 0 as an output pin.
This shouldn’t send any electrical current through the cable to the camera that could damage it, correct?
Or do I need to connect it in a different way? I don’t want to risk damaging my $1600 camera. 🙂
Veröffentlicht : 25/01/2025 4:35 pm
Zemistr
(@zemistr)
M262 P0 B0
M264 P0 B1
G4 P200
M264 P0 B0
Veröffentlicht : 25/01/2025 4:46 pm
LarGriff
(@largriff)
You’re correct on the cable hookup.  The connection will appear to your camera exactly the same as a micro switch.  All it does is closes a circuit, just like the micro switch does.  You’ll need to add gcode for the layer changes, per the video.  I look forward to seeing some time-lapse video from you soon!
Posted by: @512mb
Veröffentlicht : 25/01/2025 4:53 pm
Sembazuru
(@sembazuru)
Posted by: @largriff
Posted by: @512mb
It depends on the signaling of his microswitch. If the microswitch connects to ground when closed then yes, the GPIO board (which mostly acts like a microswitch to ground) should work, and won't need a debounce circuit. If his microswitch connects to some logical high signal there might be some additional circuitry required.
Without knowing the details of the camera trigger circuit (schematic, signaling levels, etc) that already works with his camera, I'm unable to give more than the hand-waving paragraph, above.
See my (limited) designs on:
Veröffentlicht : 25/01/2025 7:25 pm
Zemistr
(@zemistr)
I already wrote answer here but I see it is "Awaiting moderation" 😡
So I gave the answer again on Youtube, where @512mb also asked.
Veröffentlicht : 25/01/2025 7:28 pm
512MB
(@512mb)
Hello again!
Thanks for all your help! This made it much easier to decide on buying two Prusa MK4S printers and later a Prusa XL.
I’m going to wait until summer to purchase the XL, as I’m not sure if they’re planning to release an upgraded “S” version of the XL anytime soon.
Thanks again!
Answer to my questions:
"RE:
I am just checking the Canon R8.Cable Jack 2.5 mm to Jack 2.5 mm is just plug and play.
The pins in the open drain section are not able to send any current to nowhere.They are basically just connecting pin from the open drain section to the GND.
Use M262 P0 B0 to set the pin 0 as output.Use M264 P0 B1 to connect the pin 0 to GND.Use G4 P200 to wait 200ms.Use M264 P0 B0 to disconnect the pin 0 from GND.
M262 P0 B0 M264 P0 B1 G4 P200 M264 P0 B0
Btw... I am using Canon R5C... 😅"
Veröffentlicht : 27/01/2025 6:15 am
Zemistr
(@zemistr)
No problem ☺️
I'm still doing more tests and writing a script for a new video.
I can't decide whether to split the video into two or more parts, as the video will already be full of information and around 15 minutes long. 🥲
Veröffentlicht : 27/01/2025 10:47 am
512MB
(@512mb)
Just a suggestion: split it into two parts.
One part could explain how you did it, covering things like what to keep in mind regarding lighting, F-settings, and how fast a photo should be taken, such as 1/110 shutter speed, etc.
Then, it might be good to add details about using the electronic shutter, how to write G-codes, and how to adjust things like the length of pauses.
Later, you could dive deeper into camera settings, theory, and important considerations to keep in mind, etc.
Veröffentlicht : 27/01/2025 11:29 am
Zemistr
(@zemistr)
That's more or less how I wanted to do it. 😅
  1. what you need to know, camera settings, setting the environment, different looks with different apertures, converting photos to video
  2. wired shutter, which yes and which no, g-code and slicer settings
  3. wireless shutter, which yes and which no, camera settings, g-code and slicer settings
It would be better to put it all in one video, but if you're interested in a wired trigger, you don't want to spend another few minutes watching information about wireless triggers and the changes needed.
Veröffentlicht : 27/01/2025 11:40 am
Zemistr
(@zemistr)
Actually 4 videos, because one will be for some extra info 😎
Veröffentlicht : 27/01/2025 11:45 am
512MB
(@512mb)
This is something that will become the recommended series for the future! Sounds super exciting! Looking forward to watching these videos!
I also know that others are using a microswitch without the GPIO board. In the video, he uses a microswitch on the X-axis, right side. Maybe a good alternative without GPIO 🙂
Check out the video:
Veröffentlicht : 27/01/2025 3:35 pm
LarGriff
(@largriff)
I like the creation of a purge tower to catch strings.
Posted by: @512mb
Veröffentlicht : 27/01/2025 4:00 pm
Zemistr
(@zemistr)
I tried the same procedure with the tower, but it consumed too much filament and it did not work well with the MMU.
So I decided to use a column with a cross in the middle.
Veröffentlicht : 27/01/2025 11:12 pm
512MB
(@512mb)
The video you made on how to set up a camera is really well done—great job!
Veröffentlicht : 08/02/2025 6:53 pm
512MB
(@512mb)
Hello!
I just installed the GPIO board, but the G-code isn’t triggering the camera.
Any idea why?
M262 P0 B0
G1 X241 Y201 F10000
M264 P0 B1
G4 P500
M264 P0 B0
Veröffentlicht : 08/02/2025 7:34 pm
Zemistr
(@zemistr)
Hi, can you post here please a picture of your cable and how is connected with the Prusa GPIO and with your camera?
Veröffentlicht : 08/02/2025 7:54 pm
Seite 1 / 3
