GIPO - Canon EOS R8 - 2.5mm
Seite 2 / 3
512MB
(@512mb)
RE: GIPO - Canon EOS R8 - 2.5mm
Hi, I went through your videos again and noticed that the holder I’m using doesn’t provide a good connection between the cable and the board (2.5mm jack) 🙂
Link to the model: https://www.printables.com/model/1016997-prusa-gpio-hackerboard-cover/files
I’ll be redesigning it! 🙂
Veröffentlicht : 08/02/2025 7:59 pm
Zemistr
(@zemistr)
Check the file MK4_GPIO_Cover_R2.stl which I am talking about in the video 🫡
Veröffentlicht : 08/02/2025 8:02 pm
Zemistr
(@zemistr)
Btw... The correct position is G1 X241 Y170 F10000
I made a mistake in the video. 🫣
With some cameras I had to trigger the focus first so maybe try this G-Code instead:
;Time-lapse - start
M262 P0 B0            ;Pin 0 as output
M262 P1 B0            ;Pin 1 as output
G1 X241 Y170 F10000   ;Park on possition
G4 P500               ;Wait 500ms
M264 P1 B1            ;Trigger focus
M264 P0 B1            ;Trigger shutter
G4 P300               ;Wait 300ms
M264 P0 B0            ;Release shutter
M264 P1 B0            ;Release focus
G4 P500               ;Wait 500ms
;Time-lapse - end
Veröffentlicht : 08/02/2025 8:11 pm
512MB
(@512mb)
Thank you so much! I’m using manual focus instead, so I removed the focus-related parts of the code 🙂
;Time-lapse - start
G4 P500               ;Wait 500ms
G4 P300               ;Wait 300ms
G4 P500               ;Wait 500ms
;Time-lapse - end
Veröffentlicht : 08/02/2025 8:18 pm
Zemistr
(@zemistr)
I am using the manual focus too, but I still had to trigger the focus pin. 🫡
The cable trigger works like the real button the camera.
There is also "half triggered position" which serves as focus position. 👍
Veröffentlicht : 08/02/2025 8:20 pm
512MB
(@512mb)
It still won’t take any pictures for some strange reason.
See the attached images—I'm using the same code you provided, with focus enabled.
Veröffentlicht : 08/02/2025 9:23 pm
512MB
(@512mb)
Before layer change:
;BEFORE_LAYER_CHANGE
G92 E0.0
;[layer_z]
M201 X{interpolate_table(extruded_weight_total, (0,4000), (1400,2500), (20000,2500))} Y{interpolate_table(extruded_weight_total, (0,4000), (1400,2500), (20000,2500))}
;Time-lapse - start
G4 P500               ;Wait 500ms
G4 P300               ;Wait 300ms
G4 P500               ;Wait 500ms
;Time-lapse - end
End G-Code
;Time-lapse - start
G4 P500               ;Wait 500ms
G4 P300               ;Wait 300ms
G4 P500               ;Wait 500ms
;Time-lapse - end
{if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+1, max_print_height)} F720 ; Move print head up{endif}
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
M107 ; turn off fan
G1 X241 Y170 F3600 ; park
{if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+23, max_print_height)} F300 ; Move print head up{endif}
G4 ; wait
M572 S0 ; reset PA
M593 X T2 F0 ; disable IS
M593 Y T2 F0 ; disable IS
M84 X Y E ; disable motors
; max_layer_z = [max_layer_z]
Veröffentlicht : 08/02/2025 9:28 pm
512MB
(@512mb)
If you have any ideas, please let me know! 🙂
Veröffentlicht : 08/02/2025 9:30 pm
Zemistr
(@zemistr)
Does the camera reacts when you try these steps?
Veröffentlicht : 08/02/2025 9:38 pm
512MB
(@512mb)
Hi!
I solved the issue by testing with a different 3.5mm to 2.5mm adapter, and it worked! It seems the original adapter was faulty. The camera now responds to the shutter command you provided.
Everything is working perfectly now, and I just want to thank you again for your dedication and detailed responses—they truly make a difference!
Veröffentlicht : 09/02/2025 12:18 pm
Zemistr
(@zemistr)
It's nice to hear that it worked out in the end 👏
I'm looking forward to some nice time lapse videos.
Veröffentlicht : 09/02/2025 1:08 pm
512MB
(@512mb)
Hi!
Here you can check out some of my timelapse videos! Most of them will be Prusa-only—I missed open source, so I sold my X1C 🙂
https://www.tiktok.com/@filamentfreaks/video/7470484982838906145
A huge thanks again for your help! The timelapse videos are 100x better now!
Veröffentlicht : 12/02/2025 11:09 am
Zemistr
(@zemistr)
They look amazing! 😉
Good job ☺️
Veröffentlicht : 12/02/2025 11:24 am
512MB
(@512mb)
Thanks! I'm trying to develop a workflow that makes it easy to create nice timelapse functions and allows for writing a checklist of what needs to be done, etc.
I'm working on a local .html file with checklists for everything that needs to be included. I can share it later if you're interested—I’ll probably upload it here 🙂
I'm also working on a profile where I've tweaked various settings to achieve better results (in my opinion), and I can share that as well.
Thank you again!
Veröffentlicht : 12/02/2025 11:53 am
512MB
(@512mb)
I created a checklist helper; it's still in the early stages but already has some cool features like auto-generating G-code and prompting questions to verify completed tasks. Let me know if you have any questions!
Veröffentlicht : 13/02/2025 11:34 am
512MB
(@512mb)
G-code
Veröffentlicht : 13/02/2025 11:35 am
Zemistr
(@zemistr)
That look amazing!
Could you post it on github as a gist afterwards so that we can make it a public tool using https://gistpreview.github.io/ ?
I would make a video on it and recommend it to everyone 😉
Veröffentlicht : 13/02/2025 11:43 am
512MB
(@512mb)
Thank you, if you see anything that needs to get added or changed let me know!
https://gistpreview.github.io/?d3dcf8c1e2b5fe967f8a2c2d4d7eb58a
Veröffentlicht : 13/02/2025 11:55 am
512MB
(@512mb)
Hey again!
I've tested various profiles and settings and found what works best for me. Occasionally, but very rarely, I experienced a layer shift in the Y-axis and noticed that the circular purge tower didn’t always stick properly. After making some adjustments, everything has been running perfectly!
I’ve saved the settings as a .3mf file for others to check out.
Big thanks for your first video—this wouldn’t have been possible without your help!
Veröffentlicht : 14/02/2025 11:50 am
LarGriff
(@largriff)
Very nice, @512MB !  Thanks for the helpful feedback and great tools!  Makes me want to get a fancy camera!  😉
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Veröffentlicht : 14/02/2025 2:51 pm
Seite 2 / 3
