External Buttons for Filament Loading – Hackerboard, ESP32, or Something Else?
Ondřej Kabelka
(@ondrej-kabelka)
Miembro
Hi, how can I use a hackerboard (for example) to connect 5 buttons outside the enclosure and assign them the function of loading filament using G-code from M704 0 to M704 4? Is a hackerboard and 5 microswitches enough for this? Or do I also need an ESP32 or something else?
Respondido : 25/06/2025 1:31 pm
_KaszpiR_
(@_kaszpir_)
RE: External Buttons for Filament Loading – Hackerboard, ESP32, or Something Else?
I guess it should be enough to have 5 buttons, hackerboard and tiny capacitors to keep the buttons from debouncing ( or just use buttons with such feature in them) and to trigger execution of the specific gcode file per key press.
Though with additional esp32 you would be able to do a bit more if needed.
Respondido : 25/06/2025 10:57 pm
Ondřej Kabelka
(@ondrej-kabelka)
Miembro
OK, I understand. But I don’t really want to use up 5 out of 7 pins on the Hackerboard just for buttons. Isn’t there a way to connect an ESP32 to the Hackerboard to get more options? The buttons should only be switches that trigger code in the ESP32, in my opinion. That way, I can also have the G-code stored directly on the ESP32.
Respondido : 26/06/2025 8:56 am
Ondřej Kabelka
(@ondrej-kabelka)
Miembro
But i see whats really is GPIO board. It only puts GPIO pins from xBuddy to board. GPIO isnt comunication port for external purpose.
So i must put 5 micro buttons on pins and in printed set macro.
Respondido : 26/06/2025 10:34 am
Robin_13
(@robin_13)
Look at an I2C keyboard or interface to the buttons.  Another thread talks about I2C being the communications for the Xbuddy.  Maybe work that way.
Respondido : 07/07/2025 3:12 am
