Support adhesion to part
Anyone got suggestions how to prevent the part coming loose from the supports in this part? Print pla, 0,2mm lh 0,4 mm nozzle
Questa discussione è stata modificata 3 years fa da TD162
Postato : 04/11/2023 2:15 pm
RE: Support adhesion to part
you could try to build the support into the part. A lot of tiny columns only one or two layers thick and you can easily cut them after... below use a structure like the old roman waterways: pilots with arcs on top to save material.
Postato : 08/11/2023 8:28 am
