Suddenly I can not due a color change :/
All of the sudden I can not do a color change with my PRUSA MK4, I can not get beyond this screen after the first color is ejected. I can not load a second color and am stuck at this screen.
I am using PrusaSlicer 2.6.1 and printing from the supplied USB drive
I have never had this problem in the past
Postato : 14/10/2023 10:57 pm
RE: Suddenly I can not due a color change :/
First, I'd suspect the filament sensor.
Postato : 15/10/2023 6:56 am
I also think you have a problem witht the filament sensor.
In the screen (right bottom), you can see the filament sensor say "ON", which means the printer thinks the filament is not unloaded.
Postato : 15/10/2023 12:28 pm
Your sensor is stuck - possibly jammed by a fragment of stringing.
Postato : 15/10/2023 1:32 pm
