Sudden Problems with Esun TPE
Christophe Gateau
(@christophe-gateau)
Hello!
I have a problem that appeared suddenly on my MK4 printer, printing Esun TPE.
It always worked like a charm and now its not extruding properly anymore. Anyone any ideas what could have happened?
I used the same profiles and settings as before.
Things i tried:
- Drying Filament 12h at 60C
-Printing at 250C (changed slightly but still holes in the printing)
-Printing with 150% Flowrate (changed slightly but still not good)
-Printspeed at 20mms
- cleaned extruder fans of dust
- Coldpull with PLA (Everything looks perfectly clean)
I would be very happy if someone could help me:) Anything i can test?
This is how first layer looks, finished prints look accordingly.
Respondido : 10/03/2024 9:14 am
Deltabay
(@deltabay)
RE: Sudden Problems with Esun TPE
I just noticed your dilema. I found at times my Z height was miscalibrated. Even with pla. It zero on a piece of debris stuck to plate underside. Try cleaning tip off really good. Then Rehome it. Then continue as usual. It seams s thou it is to high and not squeezing to build plate. My two bits worth.
Respondido : 10/03/2024 3:37 pm
Christophe Gateau
Thank you for your response:)
Sadly its not only the first layer, its missing in all layers. I started the print several times and cleaned the nozzle several times with the same results.
I printed some parts with PETG in between which came out great.
Any other ideas?
Respondido : 10/03/2024 7:19 pm
