Single extruder MM print wont start
yetiprinter
(@yetiprinter)
Utenti
I changed my nozzle to .6mm and also updated my firmware all at the same time and now I can't get my print to start. I did do a simple test print that had no issues, but this more complex print wont load properly on the printer. I've tried with binary gcode and non-binary gcode and the lcd screen says 'Print' but doesn't display an image and doesn't ever start.
Eventually after 30 minutes I got the message saying the bed temp would turn off due to inactivity. I haven't had any issues printing on my Mk4 before, any ideas?
The object I'm printing is the right side of this, combining the black and colored parts.
The Spartan UltiDex Cube Chest - All-In-One Cube System and Card Storage. Holds 1000+, 8 or 9 100 Card Commander Deck Boxes by Hugh Kha | Download free STL model | Printables.com
Tool Change GCode
{if layer_num >= 0}
    local next_filament = filament_settings_id[next_extruder];
    "M117 " + next_filament + "
    M600 ; change to filament for extruder {next_extruder + 1}
{endif}
Best Answer by ironfan72:
This has been reported elsewhere and seems to be an issue with the 5.1 firmware,
https://forum.prusa3d.com/forum/prusaslicer/manual-multicolor/paged/6/
and also reported as a bug on github, https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3525
The work around is to start the print from PrusaLink or PrusaConnect if you have either available.
Questa discussione è stata modificata 2 years fa da yetiprinter
Postato : 28/11/2023 4:29 pm
ObedMuro
(@obedmuro)
RE: Single extruder MM print wont start
i have the same issue, im triying to print multiple color on same layer, but when i select file on my mk4, same as you, black screen top saying printing, i doesnt let long as you at 2mins, I reset the printer. I have the last official firmware, and  prusaSlicer 2.7.0.
Postato : 28/11/2023 7:09 pm
ironfan72
(@ironfan72)
Postato : 29/11/2023 4:51 pm
3 persone hanno apprezzato
