Seams seems to be dragging
Hi;
I'm printing this box in PETG on my MK4 using using Esun White Filament that has been dried for over 15 hours.
In the first picture you can see where the seam is and after the seam it creates these dragging filament pieces, the second pic shows the orientation on the bed.
Why would this do this , is this bad orientation , part cooling fan issue ?
All Hardware is stock standard, Printed in the Prusa Enclosure with doors closed.
Current Firmware 6.0.4 and sliced with Prusa Slicer 2.8
Nozzle : 0.4 ObXidian with a silicone sock
Print Settings:
- 0.2mm Structural
- 10% Gyroid Infill
- 230 Deg first layer 240 Deg rest
- 85 Deg Bed 90 Deg other layers
- Arachne Rear Seem position
Opublikowany : 06/08/2024 4:12 pm
