Requests filament change just before starting to print on only one filament profile
Having a strange issue with a particular filament profile. I copied the Das Filament PLA profile and modified the bed and nozzle temperatures. Anytime I try to print with that profile I get a "Reloading Filament" message followed by a "Stuck Filament Detected" right after it does it's last nozzle purge/sweep to begin printing. If I unload and reload the filament it resumes the print and everything works fine. I do not get this behavior when I use the default Das Filament PLA profile, the Prusament PLA profile or a copied profile of the Generic PETG profile which I modified for Das Filament. If I turn off the "Stuck Filament Detection" setting it works as expected. Tried recopying the default profile multiple times with the same results. What am I missing here?
