Problems with printing tilted slope
Atropin
(@atropin)
Hello everyone,
I am trying to print the object you see in the images, but my every attempt ends up in a disappointment.
The issue is the tip at the very bottom of the slope, and uneveness of the sloped surface.
So before wasting any more of my time (and filament) I’ve decided to ask you guys for some advice.
I’m not sure this has to do with the supports - they seem pretty solid.
Napsal : 23/12/2023 1:36 pm
RE: Problems with printing tilted slope
It would be useful if you could share some details about your settings. This is not a great model for 3d printing — as a designer, I would have broken it into three parts that could all be printed easily without supports—but it should print okay.
If you save the file from Prusaslicer as a 3mf project file, compress it with your OS's compress utility, and then upload the resulting .Z file here by using the Attach file button under the text edit window, we can see all your settings. File has to be compressed, or the forum software won't accept it.
Napsal : 23/12/2023 2:55 pm
Atropin
(@atropin)
Yes, I wanted to add the slicer file but I didn't know it has to be compressed. Thank you for claryfying! Smashing Fyyran_2_v2
Napsal : 23/12/2023 3:11 pm
